Files long time to open in Autocad 2014
ennujozlagam
Mentor Mentor
738 次查看
7 条回复
1 条消息(共 8 条)
ennujozlagam
to Autocad expert. i have a few files that it take a longer time to open, i already tried everthing purge, scalelistedit, audit, flatten, dxfout , dxfin but still the same no changes. what could be the reason??
And i tried also to DGNPURGE but there is a error comeout (Please see attached)
Any help , suggestion is much appreciated. thanks
0 个赞
739 次查看
7 条回复
回复 (7)
2 条消息(共 8 条)
rkmcswain
Is the file size much larger than it should be? (I cleaned some last week for a co-worker that were 100MB in size before and less than 1MB after).
My guess is that it's infected with the DGN linetype bloat. I don't know why you're getting that error while using DGNPurge. Do you have the very latest version of that tool?
R.K. McSwain     | CADpanacea | on twitter
0 个赞
3 条消息(共 8 条)
Volker_C
Autodesk Support
Autodesk Support
As rkmcswain mentioned this could be an issue with DGN linetypes bloating the drawing file. Having said that, I notice that there are a few things which you did not mention having tried. Give the following a go:
  1. AUDIT command to fix file errors
  2. Then use the "-Purge" command and select "R" for Regapps
  3. Followed by "-Purge" or Purge to remove remaining unreferenced entities.
Review the following document for additional information about fixing corrupted drawing files. If none of these solutions work, please post the drawing file so that we can take a look at it.
Cheers,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
CTS Technical Enablement Specialist | AutoCAD
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
0 个赞
4 条消息(共 8 条)
ennujozlagam
@rkmcswain , thank you for your reply, yes i have the latest version of that tool.
Latest updates of all service packs and hot fixes and graphics card driver , OS . etc is not an issue i had all updated. And is not also a network problem because i copied to my C: drive and open from there, still facing the same issue. The file size is just only 2,387 KB thats the reason why i posted this issue here. i really dont know what is the caused of this problem. thanks
0 个赞
5 条消息(共 8 条)
ennujozlagam
@Volker_C. thank you for your reply. i did mentioned in my post audit and already tried everything all your suggestion before and still doesn't work at all.
Due to the confidentiality  and non disclosure agreement, i cannot post the files here. thank you.
0 个赞
6 条消息(共 8 条)
Volker_C
Autodesk Support
Autodesk Support
Thanks for the feedback. I'm sorry to hear none of those solutions worked for you. I understand the confidentiality clause. are you able to email me the file? As a subscription customer we at Autodesk are under a Non-Disclosure Agreement with you.
Some additional solutions (shall we call them work arounds):
After WBlocking the file, insert the file into a blank (new) drawing template such as acad.dwt.
An alternative would be to turn on and thaw all layers. Then copy all objects to the Windows Clipboard. Finally, paste them into a new drawing template.
One additional question, are you using constraints?
Cheers,
Volker
Volker C.
0 个赞
7 条消息(共 8 条)
ennujozlagam
hi, thanks, i already did that wblock and start new drawings and windows clipboard. no i did not use constraints i can also use delconstraint. i'm not too sure if can send it to you need approval first from the management. I will try my best to solve this issue again. Anyways thank you for your help much appreciated.
0 个赞
8 条消息(共 8 条)
rkmcswain
ennujozlagam wrote:
.....i already did that wblock and start new drawings and windows clipboard.
When you used the WBLOCK command, did you choose "Entire Drawing" or did you select objects?
You should do the latter, and if that doesn't work - repeat the process but only export a subset of your layers each time.  At some point you should be able to narrow down the problematic objects.
As as test, save the drawing down to R12DXF format, then open up that DXF and save back to DWG.
Any better?
0 个赞
