how to create CTB files
i would like to know, the procedures of creating CTB and the formating the CTB styles
ennujozlagam
hi, there are two options you have. "CONVERTPSTYLES" or "CONVERTCTB". Thanks
or you may check it here previous threads;
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/new-student-unable-to-change-plot-styles/t...
imadHabash
to creat a new CTB file you have to follow a number of simple procedure.start from PLOT command line then from plot style table select NEW as attaached image.
PLOT >> plot style table >> NEW >> start from scratch >> file name >> plot style editor.
in the last procedure go to lineweight to change you pen width as your need after selecting your color...
Good Luck.
Imad Habash
GrantsPirate
Neither of those commands are the answer.  CONVERTPSTYLES converts a .dwg file from using one plot style to another.  CONVERTCTB converts a .CTB to .STB.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
ВeekeeCZ
Maybe this video is more revealing.
https://www.youtube.com/watch?v=zeItgdhUrTM
But I do recommend learn about STB as well. STB is newer, more powerful and probably easier to handle - especially with more complicated and more colorful drawing.
https://www.youtube.com/watch?v=Rdaov8SGjpw
GrantsPirate
Also use STYLESMANAGER command from command line or from the 'Big A', print, Manage Plot Styles.
GrantsPirate
EXPERT ELITE MEMBER
