FATAL ERROR: Unhandled Access Violation Reading 0xfffffff Exception at fae6a41a
rhys.hughesEDGHC
Message 1 of 8
rhys.hughesEDGHC
Can anyone assist with this?
I thought it was a graphics card issue so I have updated this and it seems to keep happening.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
most important: Please let us know which product and version you have? Please start command _ABOUT and show us a screenshot.
Additional info:
  • which operating system
  • which graphic card
  • when does this exception appear
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
rhys.hughesEDGHC
AutoCAD LT 2015
Graphics Card: NVIDIA Quadro FX 1800
Windows 7 Professional
It happens totally randomly, I thought it may be a corrupted drawing but I have worked on many different drawings since and it seems to happen a couple times a week, I also checked to see if there was any memory issues but everything on task manager seems to be running smoothly
Message 4 of 8
rhys.hughesEDGHC
FYI
Message 5 of 8
Alfred.NESWADBA
well, FX1800 is quite old, and as you are using AutoCAD LT I guess you don't have 3D drawings and also not too big drawings. So I would suggest to disable hardware acceleration (command _GRAPHICSCONFIG) and see if the crashes get better (or worse).
Next step would be to reset settings to default, but as that would remove your customization's I would first test the graphic card/-driver before doing that step.
- alfred -
Alfred NESWADBA
Message 6 of 8
rhys.hughesEDGHC
Hi
My hardware acceleration is already disabled - what would be the best way to test the graphics card?
Kind Regards,
Rhys
Message 7 of 8
Alfred.NESWADBA
Well, then try to reset settings to default >>>details<<<
When AutoCAD starts then please do not migrate settings if you are asked to do that (not sure if you have another version of AutoCAD installed, also don't know if LT has such an option).
I don't know a specific test with AutoCAD, only the way to see if AutoCAD works more stable when hw-acc is OFF.
- alfred -
Alfred NESWADBA
Message 8 of 8
pendean
Community Legend
Community Legend
There is no fix for "totally randomly": you will need to better identify the trigger (hard to do sometimes), it may be your files or something you've added to your 6+year old setup today that did not exist in the years of smooth sailing you've enjoyed so far.
How to fix DWG files https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
