FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at ebfbf78ch
I've been using AutoCAD 2018 student version for a while on Windows 7.
All the sudden, if I make any trim or multiline edit, the software just crashs with error sign:
I searched past issues and followed the nohardware which did not worked.
I also reinstalled the entire software but is is still doing to same thing.
Please help me with this issue.
lynn_zhang
Hi @sunhoro
Have you tried the solution in this link: Fatal Error: Unhandled Access Violation Reading 0x0088 Exception at c3328a72h when opening a drawing... ?
Lynn Zhang
Its not that issue. Starting up the CAD and opening up the dwg file works fine. But when I try to use trim related tools ,my cad just crashes.
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Can you try to check the solutions suggested in this forum: AutoCAD 2018 - Trim Crash.
Let us know how it goes.
AmandaWong
Autodesk Customer Support
wongam
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just checking in. How's it going with your AutoCAD?
AmandaWong
So my problem is with the multi line editing tool.
When ever I use it, cad crashes.
I tried with all the solutions provided but none works.
Please help me out if there is any other solutions.
Thank you.
