Fatal Error AutoCAD 2016
Message 1 of 31
when i am going to open drawing, every time i got FATAL Error, it shows different when i open drawing multiple times. i need urgent solution. Also i upgraded all my system files, autocad files, graphic card.
Replies (30)
Message 2 of 31
Otto
Hello it and welcome to the Autodesk community!
It looks like you are looking for information related to a fatal error when opening drawings. Community members with similar questions found the following article(s) useful:
RECOVER (Command)
Submitting & Viewing Support Requests
AutoCAD appears to freeze or hang during startup
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 31
i also tried this so many times, but nothing changed. I need a proper solution as this error interrupt my work and my time, and this drawing is so important and crucial.
Message 4 of 31
Slawomir_
Try to RECOVER your drawing (see picture). Or find bak file of your drawing, copy it and change extension to dwg.
Message 5 of 31
As i mentioned earlier that i already did this so many times, but nothing changes, every time i opened the drawing after application crashes the error also changed. see attached screen shot
Message 6 of 31
Slawomir_
Have you checked if your hardware is recommended by Autodesk? I too encounter issue called FATAL ERROR. In my case GRAPHICSCONFIG (see picture) configuration helps.
Message 7 of 31
I am using NVIDIA Quadro M4000. so this model is good for Auto Cad Design Suite Standard 2016?
Message 8 of 31
Slawomir_
There is Quadro 4000 and K4000 on the list (click link), however 2016 is not listed. Don't know why.
Message 9 of 31
Yes i can see, but M4000 is not in this list. Actually i have two Machines with same configuration and graphic card. One is working fine but this issue with the another machine, so is it possible that the issue is because of LCD.
Message 10 of 31
Slawomir_
Doe's your drawing opens on second machine? If yes, issue is with software configuration.
I've done some research, and you might find some helpful (hopefully) troubleshooting articles:
Images in a drawing can crash AutoCAD 2016
AutoCAD crashes when saving, closing, or plotting a drawing or when exiting the program
AutoCAD crashes after installing Windows security update
Message 11 of 31
yes this drawing is open on another machine without any error
Message 12 of 31
Slawomir_
Perhaps full uninstall and reinstall of AutoCAD will help?
Fatal error while launching AutoCAD
Message 13 of 31
already did this 3 or 4 times, same error, upgrade all the things same error
Message 14 of 31
Slawomir_
A hard nut to crack.
Maybe run AutoCAD with DirectX 9?
Otherwise I recommend to contact technical support.
Message 15 of 31
john.vellek
Hi @Anonymous,
If you are running Windows 7, 8 or 8.1 this appears to be the current graphics driver for your card.
If Windows 10, try this one.
Please also check to see that you have applied the hotfixes and service pack from here for AutoCAD 2016. Can you post a screen grab of your GRAPHICSCONFIG window for me?
Lastly, if this feels like it might be drawing specific, please attach a sample file for me. It appears from your images that you have a lot of hatches and perhaps other complex geometry. I would like to see if I can find anything in your drawing that might cause this problem.
John Vellek
Message 16 of 31
Hi john.vellek,
Yes i am using windows 10, and i already upgrade my graphic card. Please check the attachment of Graphic card configuration
Message 17 of 31
Slawomir_
Have you tried to PURGE and AUDIT your drawing on second machine and then opening on first one?
Message 18 of 31
yes about 2 weeks ago the drawing opened perfectly. after sometimes FATAL Error came but not every time. i tired this before what you said. but no result
Message 19 of 31
Slawomir_
You can post drawing, I will try to open & repair it.
Message 20 of 31
I am sorry for that, i can not upload, because i need approval from my management to upload drawing. Actually the problem is not with one specific drawing. Its comes randomly. and the other thing is these drawing are placed on a network share folder. and i don't know when this error switches to another drawing. I checked this error comes with 2 or more drawings
