Fatal Error AutoCAD 2016
Message 1 of 31
when i am going to open drawing, every time i got FATAL Error, it shows different when i open drawing multiple times. i need urgent solution. Also i upgraded all my system files, autocad files, graphic card.
Replies (30)
Message 22 of 31
john.vellek
Hi @Anonymous,
What exact build of Windows 10 is running on your system? I see that this is the certified driver Windows 10 64bit [10.18.13.5456].  It sounds like a Windows update two weeks ago might be causing this issue. Is it possible to uninstall the update to see if things improve?
You might also consider removing and reinstalling the C++ and .Net Framework on your system.
You are welcome to directly send me a sample file at [email protected]
John Vellek
Message 23 of 31
Hi john.vellek
I reinstall everything including Windows, but the problem is still there, the drawings are not open.
Message 24 of 31
Thanks both of you guys, for your time and help. The error is gone now, and the drawing now open on the machine, after reinstalling each and everything including Windows and servicepack. again thanks so much for you help
Message 25 of 31
I have done all things which you share us but the issue is fix temporary and after some time the error will come in new file.SUGGEST us what can i do bzc i am not able to work.
Message 26 of 31
the same things i have done but problem not fix yet.
Message 27 of 31
I have done all things even windows reinstall many time and also uninstall C++ which updates i should uninstall.
Message 28 of 31
please help out this issue
Message 29 of 31
no one answer me i have facing this issue last month what can i do lots of work is pending by me please us some solution.
Message 30 of 31
Slawomir_
Message 31 of 31
john.vellek
Hi @Anonymous,
I am sorry this problem has returned. Can you check to see which version of .NET Framework is installed on your WIndows 10?  There are known issues with .NET 4.7.
If you feel that this is file specific I welcome you to attach it to a post so I can take a look.
Since this problem returns can you verify that a Windows update or a driver change occurs at approximately the same time frame? If so, can you isolate which ones get installed that might cause this problem?
Since this keeps coming back and it you feel these suggestions don't resolve your problem quickly enough, I encourage you to schedule a call with technical support so as to receive more immediate help.
John Vellek
