Trying to pull the total SF for the Walkways in this plan
The layer is "Walk" but I don't think it is possible, correct?
Solved by vinodkl. Go to Solution.
Solved by pendean. Go to Solution.
LIST and PROPERTIES commands can offer up what you need if you can be careful on what you choose in modelspace
Then there are LISP tools to do way more, explore these
https://www.google.com/search?q=autocad+lisp+for+hatch+areas
Hello @npdipietrop26
You can isolate the particular layer using the command "LAYISO" and then use the attached lisp file from Leemac to get the total sum of the hatch area. Use the command "APPLOAD" to load the attached lisp and then type in the command "TAREA" to execute the lisp.
