Dwg file not valid
Dwg file not valid
castepp14369
Message 1 of 8
Dwg file not valid
castepp14369
I have AutoCAD 2024 and Inventor 2024 installed on my computer. I am currently working through the certification on AutoCAD itself, so the DWG came from AutoCAD. I am unable to open the DWG file through the Inventor ACAD or through AutoCAD itself. It says the file is not valid. It also will not even preview the file for me. I've deleted and redownloaded the files many times. I can replicate the sketch for the module by watching the video but I'm assuming this situation will pop up again. Any help would be greatly appreciated. Thank you in advance.
Accepted solutions (3)
Replies (7)
Message 2 of 8
Valentin_CAD
@castepp14369 ,
Did you Unzip the files?
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 8
paullimapa
Actually your screen capture just shows that the dwg file is read only. Though I do find it strange that a dwg file name would begin with a period and underscore
Paul Li
IT Specialist
@The Office
Message 4 of 8
pendean
Community Legend
Community Legend
You are working through a ZIP file: a big no-no. Unzip it to a folder, than use the files all you want.
Since you appear to be mac based... https://support.apple.com/guide/mac-help/zip-and-unzip-files-and-folders-on-mac-mchlp2528/mac#:~:tex....
if not, then https://support.microsoft.com/en-us/windows/zip-and-unzip-files-f6dde0a7-0fec-8294-e1d3-703ed85e7ebc....
Message 5 of 8
DarrenP
I am not seeing where it says the file is invalid
Where are you seeing this?
DarrenP
Message 6 of 8
castepp14369
Screenshot 2023-08-23 012733.pngWhen I try to open the file in AutoCAD.
Message 7 of 8
vinodkl
Hello @castepp14369
Please share the drawing so that we can test it from our end.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 8 of 8
paullimapa
You're accessing the zip file to drawings in the wrong location.
Don't look for dwgs in the _MACOSX folders:
Otherwise like you show, you'll get the following error message:
Instead look for dwgs under the folders that begin with 201015_***:
I downloaded the same datasets.zip from the Autodesk Certification Inventor Mechanical Design website and properly located the dwg file and attached is the Bottle Cap.dwg that opens perfectly fine in AutoCAD.
I knew files beginning with ._*** cannot be right.
Paul Li
IT Specialist
@The Office
