AutoCAD Forum
extrusion of closed lignes
4 REPLIES 4
tran_ha90c1
255 Views, 4 Replies
I would like to do an extrusion in the 3D environment.
I have lines with rounded corners as you see in the photo.
When I did the extrusion, the roundings are not done, do you know why and do you have a trick to fix it?
Thanks you
4 REPLIES 4
Patchy
in reply to: tran_ha90c1
Pedit, join and input some fuzz length or try BOUNDARY command and see.
pendean
What does "roundings not done" mean please? a screenshot of that too would be helpful.
Of did you forget to ensure your entire shape was a closed pline first?
tran_ha90c1
@pendean it's pretty what u did, but I got that :
display your model in Conceptual Mode, you'll see.
pendean
Forma Design Contest
AutoCAD Beta
