Express Tools Text Mask problem resize factor offset & border color
neam
Message 1 of 14
neam
Hi everyone:
When I move or copy the masked text, the offset factor and border color are changed.
This problem only occurs in my AutoCAD.
"""Autocad Civil 3d 2019"""
Replies (13)
Message 2 of 14
neam
I don't know if this post is in the right place in this forum or not.
Message 3 of 14
MMcCall402
I'm not able to produce the issue in version 2024.  The group copies and moves as expected.
Another option would be to do this using Mtext with a frame and background mask.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 4 of 14
AllenJessup
I can't duplicate it in 2004 either. I haven't used that tool in a long time. As @MMcCall402 mentioned. I use MText with a background mask.
Allen Jessup
CAD Manager - Designer
Message 5 of 14
neam
Dear sir:
That's absolutely correct.
You don't have this problem in your AutoCAD and this problem is not visible.
I don't know what, where, when, or how the variable was applied that caused this problem.
Message 6 of 14
neam
Hi sir:
Please pay attention to my last comment.
Message 7 of 14
neam
Is it possible that this problem is due to the installation of some add-ins?
Message 8 of 14
neam
Is it possible that the answer to this problem can be found in another forum?
If so, how can I move this post to that forum?
Message 9 of 14
neam
Message 10 of 14
AllenJessup
It's possible there might be an answer in the AutoCAD Forum. If you want to request the post be moved. Use the Report button. That will get your request to the Admin.
Allen Jessup
Message 11 of 14
neam
Has anyone encountered such a problem?
Message 12 of 14
TomBeauford
I do remember it being a pain including having to select and move both text and border to the front but like everyone else switched to using Mtext with both border and background that automatically resize when the Mtext is modified.
I haven't used Text Mask or even plain Text in years. Maybe it's time you make the switch yourself.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 13 of 14
AllenJessup
I think you'd only have to select both if PICKSTYLE was set to 0.
Allen Jessup
Message 14 of 14
TomBeauford
Using plain text you have to select each line of text and the border to move to front, using Mtext with border and background it's just one object but you wouldn't need to modify it anyway.
2023
