AutoCAD Forum
Express Tools Text Mask problem resize factor offset & border color
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
neam
394 Aufrufe, 13 Antworten
Hi everyone:
When I move or copy the masked text, the offset factor and border color are changed.
This problem only occurs in my AutoCAD.
"""Autocad Civil 3d 2019"""
Tags (1)
13 ANTWORTEN 13
Nachricht 2 von 14
neam
als Antwort auf: neam
I don't know if this post is in the right place in this forum or not.
Nachricht 3 von 14
MMcCall402
I'm not able to produce the issue in version 2024.  The group copies and moves as expected.
Another option would be to do this using Mtext with a frame and background mask.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Nachricht 4 von 14
AllenJessup
I can't duplicate it in 2004 either. I haven't used that tool in a long time. As @MMcCall402 mentioned. I use MText with a background mask.
Allen Jessup
CAD Manager - Designer
Nachricht 5 von 14
neam
als Antwort auf: MMcCall402
Dear sir:
That's absolutely correct.
You don't have this problem in your AutoCAD and this problem is not visible.
I don't know what, where, when, or how the variable was applied that caused this problem.
Nachricht 6 von 14
neam
als Antwort auf: AllenJessup
Hi sir:
Please pay attention to my last comment.
Nachricht 7 von 14
neam
Is it possible that this problem is due to the installation of some add-ins?
Nachricht 8 von 14
neam
Is it possible that the answer to this problem can be found in another forum?
If so, how can I move this post to that forum?
Nachricht 9 von 14
neam
Nachricht 10 von 14
AllenJessup
It's possible there might be an answer in the AutoCAD Forum. If you want to request the post be moved. Use the Report button. That will get your request to the Admin.
Allen Jessup
Nachricht 11 von 14
neam
Has anyone encountered such a problem?
Nachricht 12 von 14
TomBeauford
I do remember it being a pain including having to select and move both text and border to the front but like everyone else switched to using Mtext with both border and background that automatically resize when the Mtext is modified.
I haven't used Text Mask or even plain Text in years. Maybe it's time you make the switch yourself.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Nachricht 13 von 14
AllenJessup
als Antwort auf: TomBeauford
I think you'd only have to select both if PICKSTYLE was set to 0.
Allen Jessup
Nachricht 14 von 14
TomBeauford
Using plain text you have to select each line of text and the border to move to front, using Mtext with border and background it's just one object but you wouldn't need to modify it anyway.
2023
AutoCAD Inside the Factory
