Hi everyone:
When I move or copy the masked text, the offset factor and border color are changed.
This problem only occurs in my AutoCAD.
"""Autocad Civil 3d 2019"""
Gelöst! Gehe zur Lösung
Gelöst von TomBeauford. Gehe zur Lösung
Gelöst von MMcCall402. Gehe zur Lösung
I can't duplicate it in 2004 either. I haven't used that tool in a long time. As @MMcCall402 mentioned. I use MText with a background mask.
Allen Jessup
CAD Manager - Designer
Dear sir:
That's absolutely correct.
You don't have this problem in your AutoCAD and this problem is not visible.
I don't know what, where, when, or how the variable was applied that caused this problem.
Is it possible that this problem is due to the installation of some add-ins?
Is it possible that the answer to this problem can be found in another forum?
If so, how can I move this post to that forum?
It's possible there might be an answer in the AutoCAD Forum. If you want to request the post be moved. Use the Report button. That will get your request to the Admin.
Allen Jessup
I do remember it being a pain including having to select and move both text and border to the front but like everyone else switched to using Mtext with both border and background that automatically resize when the Mtext is modified.
I haven't used Text Mask or even plain Text in years. Maybe it's time you make the switch yourself.
I think you'd only have to select both if PICKSTYLE was set to 0.
Allen Jessup
