Explode Scale modified Block in AutoCAD
Message 1 of 10
I modified scale of a 3d block to be different in different axes, now I am happy with the result, but I want to do some modifications and I want to explode the block, AutoCAD telling me is it can be exploded.
BTW: the properties of the block in the block editor Yes in allowed exploding.
Hamno
Replies (9)
Message 2 of 10
Hamno
Post your drawing.
Message 3 of 10
AutoCAD will not allow you to explode a non-uniformly scaled block.
Use BEDIT to edit the block definition to redefine the block, or use the non-uniform block as a template and build over it.
You can ask over at the LISP forum to see if anyone has a programmatic solution.
Message 4 of 10
Kent1Cooper
That's not true as a general statement -- it lets me, even with a 3D Block with different scales in all three directions, if it's made up of more ordinary pieces [in the case of my test, Lines].  But it won't allow it if the content of the Block includes 3D Solids [and perhaps there are other things that would be disallowed].
Kent Cooper, AIA
Message 5 of 10
Well I'll be.  I've been using AutoCAD since 1984 and it would never let me explode non-uniformly scaled blocks regardless of content.   I know it didn't work in 2002 and I guess I've never tried since.  But now it does, wonder when that changed?  I'm getting too old for this stuff.
Message 6 of 10
john.vellek
Hi @Anonymous,
I believe version 2004 or 2006 allowed the exploding of non-uniform blocks. This still isn't possible though if the blocks consist of 3d solid objects.
John Vellek
Message 7 of 10
And that's probably why I never noticed you could explode a non-uniformly scaled block, I haven't drawn a 2D block (other than annotation blocks) since the mid 90's.
Message 8 of 10
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 9 of 10
The block contains 3d Solid, I wanted to change the height of it with out changing other two dimensions, So I recreate the whole thing. thanks for your replies.
Message 10 of 10
You could redefine the block via BEDIT.  BEDIT allows you to select the block by name from a list.
REFEDIT requires you to select the block and edit in place (which it won't do for non-uniformly scaled blocks, even without 3dsolids, I checked this time)
