new inserted block does not show up in updated table data
I am using table with data extraction, and noticed once the table is created, new block inserted into the drawing will not show up it's data when i select update table data links.....
any thoughts is appreciated.
Scott
Does the new block data match the template DXE??
Alfred.NESWADBA
Besides of Randall's feedback I just want to add:
When you created the DXE, have you selected objects to be use for _DATAEXTRACTION as "Drawings/Sheet set ..." or using the option "Select objects in ..."?
If you had selected the second option new block-insertions will never be part of the table as they were not selected at the time you created the DXE.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred:
Thanks for the info, I selected the first option, drawing/ sheetset and include current drawing.
Started with a new drawing but the new inserted block info still does not show up when I update the info.
ScottCh.
Alfred.NESWADBA
Can you upload the drawing + the DXE file and let us know, which block you did insert.
- alfred -
Alfred NESWADBA
