AutoCAD Forum
Excel DataLink in AutoCAD without Borders
4 REPLIES 4
2064 Views, 4 Replies
Is there a way to only keep the text from excel, I do not want the table borders being displayed.
4 REPLIES 4
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 Yes, you can use datalink and not have any borders when you produce your output.
When you create your data link, make sure that under the Cell Format options that you indicate that you do not want to retain formatting on updating.
Then, in AutoCAD, create a Table Style that has no borders. Apply this to the table that is created from the Datalink.
You will see the table cells with lines but they are only indicators and the lines will not print.
John Vellek
TheCADnoob
are you just wanting the words or are you wanting the table format and just not the lines.
CADnoob
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
in reply to: john.vellek
Hi @john.vellek,
I am in a similar situation as the original poster of this thread, using Civil 3D 2021.
When I have my Datalinks set to "Start with Excel formatting, do not update", the linked Tables will be properly set to my liking, but they will revert to DISPLAY as the Standard Style when the drawing is reopened and the Datalinks are updated. I have created unique styles for each of my Datalinks, and each Table will remain listed in it's respective style, but the display will revert to Standard Style.
I have tried "Keep table updated to Excel formatting", and using the unique styles for each Datalink in the formatting I desire, but they are overridden as well with displaying the Standard Style, and will remain listed in it's respective style still.
Third option is "Keep table updated to Excel formatting" and formatting my linked Excel Document to the formatting I desire, but the cell heights and borders to not retain the formatting that was done in Excel when the tables are in CAD.
It seems like the first option is the way to go on this one, as it is what you listed as a fix for the original poster, but please let me know if there is a caveat that I need to keep in mind in accomplishing this to mitigate the changes that occur when the drawing is reopened and the Datalinks are updated.
Forma Design Contest
