AutoCAD Forum
Error Found: *Warning* Multiply owned object, handle
12 REPLIES 12
Message 1 of 13
trivedikamal186
2118 Views, 12 Replies
Hello, Good Day,
Following error getting save the drawing.
please help me, how i am comply.
*Warning* Multiply owned object, handle "29"
*Warning* Multiply owned object, handle "2A"
*Warning* Multiply owned object, handle "28"
i am not use "HANDET"COMMAND. (Please share details how to use this command.
12 REPLIES 12
Message 2 of 13
It looks like you need more to the command. Enter the following in the command line.
(entdel(handent"29"))
Also check this thread to see if it helps
https://forums.autodesk.com/t5/civil-3d-forum/warning-multiply-owned-object-handle-quot-206cf-quot/t...
CADnoob
Message 3 of 13
DJB266
in reply to: TheCADnoob
This is what happens when I try this...
*Warning* Multiply owned object, handle "3DD6"
Command: entdel(handent"3DD6")
**** System Variable Changed ****
2 of the monitored system variables have changed from the preferred value. Use SYSVARMONITOR command to view changes.
Unknown command "ENTDEL(HANDENT"3DD6")". Press F1 for help.
Suggestions?
Message 4 of 13
pendean
in reply to: trivedikamal186
Message 5 of 13
DJB266
in reply to: pendean
@pendean wrote:
Do you need to fix your file(s) and Xref(s) first perhaps https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
There are no xrefs in the file.  There was one image file, but I removed that and I get the same error.
Message 6 of 13
pendean
in reply to: DJB266
But did you fix the DWG file? Erasing content is never a way to fix a problem DWG file.
Message 7 of 13
DJB266
I'm not sure what you mean.  I ran purge and audit, but no errors were found.  Are there other ways of "fixing" that you are referring to?
Message 8 of 13
pendean
in reply to: DJB266
See my earlier link for the other 4+ things you can try... .
Can you share your DWG file here for others to examine?
Message 9 of 13
JanTol82
I have the same problem with a drawing here at the office, it's an old drawing that came from another office.
There are thousands of (*Warning* Multiply owned object, handle "50E1B9F") errors in it.
The handet command didn't work and too be honest with this amount of errors it's an endless job (Would be a lot of work to type every code manually).
It's a big file and at the moment we can basically just throw it away. It has no xrefs, no images nothing of all of that. Tried everything so far but can't fix those errors. Anyone has an idea how to fix this?
Message 10 of 13
pendean
in reply to: JanTol82
>>>...Tried everything so far but ...<<<
And what were those? here is a refresher if you need it https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Message 11 of 13
JanTol82
Unfortunatley those all didn't work. Been at it for hours now. I'm about to give up. 😞
Message 12 of 13
cadffm
If you like..
Share the data package (command: etransmit the fiel with all 'include options' ON)
I am sure we can help.
Sebastian
Message 13 of 13
JanTol82
in reply to: cadffm
Thank you very much for the offer, unfortunately company policy doesn't allow that.
We found the blocks with the errors and are now in the process of redrawing the blocks to get ride of the errors.
Forma Design Contest
AutoCAD Beta
