I'm trying to convert legacy notes that are MTEXT paragraphs with a separate number text (1 thru 27 in this instance) in front of each paragraph. When I double click on the first paragraph, the Text Editor contextual tab appears where I can select Numbered from Bullets and Numbering and the first paragraph gets a 1. in front of it. If I pick all of the paragraphs at once, I can't double click and get the Text Editor contextual tab, all I get is a properties dialog box with Mtext(27) as its header.
How can I get all of the paragraphs numbered in one operation?
Select all the paragraphs and run the Express Tools command "txt2mtxt". It will combine all the single Mtext paragraphs into a single block of Mtext. You can then double click it and add the bullets and paragraph spacing if needed.
