dwg to PDF prints problems
Message 1 of 22
i open a dwg created with autocad 2007 , when i go to print pdf , autocad chash with error and close application
i use autocad 2017 lt now , the machine is core i 7 with nvidia 1060 , 16 ram , ssd , windows 10 64 bit
I unistall adobe reader but i have same problem
if i open a file dwg and modify , print pdf crash , if i don't modify i work normally.
thansk michele
Replies (21)
Message 21 of 22
So' it seems a problem form 2007 version opened in 2017 ?
Thanks Michele
Message 22 of 22
john.vellek
HI @Anonymous,
I don't think this has anything to do with the file format. It appears to be something in the PDF Driver.  I am bringing this issue to the team for them to examine but in the mean time I suggest you try a different PDF driver to see if you can continue
John Vellek
