AutoCad 2018 restarts my PC??
ruhan.louw
Observer Observer
Message 1 of 9
ruhan.louw
Observer
Observer
HI
my laptop keeps restarting every time i use autocad 2018 for about 5-10 minutes.
do you have any suggestions for me on how to prevent this from happening?
Laptop specs:
Device: HP Beats 15 notebook pc
processor: ADM A8-5545m APU with Radeon(tm) HD Graphics   1.70GHz
ram: 8GB
Replies (8)
Message 2 of 9
DarrenP
your computer could be overheating
i would start troubleshotting hardware issues
DarrenP
Message 3 of 9
ruhan.louw
Observer
Observer
hi DarrenP
my pc does get hot at times but ill give it a try. how can i do the trubbleshoting?
thanks
Message 4 of 9
john.vellek
Hi @ruhan.louw,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Please start Task Manager and keep an eye on what is running in the background when you have AutoCAD up.  I am curious if Acwebbrowser or Chromium Host Processes are launching numerous times and running the CPU at full throttle.
John Vellek
Message 5 of 9
ruhan.louw
Observer
Observer
Hi @john.vellek
Ive kept my eye on the task manager and closed all unnecessary processes running in the background and it seems to be working. I will just have to work slowly on the program. I did try to change some settings in the CUI and when I pressed apply it caused my pc to restart again. I am able to work on the program again but cant change any CUI settings. Any suggestions for that problem?
Message 6 of 9
john.vellek
HI @ruhan.louw,
This actually sounds like a corrupt installation of AutoCAD.  has it been running until just recently or is this basically a new install?
Here is an article that details that it might be necessary to perform a clean reinstall.
John Vellek
Message 7 of 9
Alfred.NESWADBA
To be honest, I don't think so. If AutoCAD crashes ok, that might be a bad installation. But if the system restarts itself when AutoCAD crashes, that is a hardware or driver issue.
@ruhan.louw
You might look for stress tests, heating up processor as well as graphic card unit + memory and see if the same happens.
Also look to the Windows Event Viewer and see if that has some useful input about the reasons of crashing the workstation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 8 of 9
john.vellek
Hi @ruhan.louw,
I have tried to look up the specs on your laptop but there are several variations.  I suspect that the hardware does not meet the system requirements.  Can you verify that for me?
John Vellek
Message 9 of 9
pendean
Community Legend
Community Legend
Take your laptop to a PC service center and demonstrate the problem since it seems to only take 5-10 minutes to trigger: they will be best at providing you with a diagnosis.
