How to get the block attribute #Field visibal with Measur>>Block command
Hi @arshadmirza786, After using the measure command use ATTSYNC command and the select option then select the block and then Yes to sync the block and the attributes should display.
Your blocks that you have placed on the red dashed line are not showing the northing and easting position because those block don't have attributes. Only the block farthest to the north is working. That block not only has attributes, but it has the appropriate fields to determine the block's position. You should copy that good block and use it to replace the blocks on the dashed line.
To check a block, click on it. With the block selected, go to properties palette and scroll to the bottom. Under the block name, you will see the attribute tag and the attribute value. If attributes are missing from the properties palette, then it doesn't have any attributes, and if it doesn't have attributes then it can't hold a field. Image below shows a block named AMNorthEast with two fields: E and N.
This the good block. It has two fields: E and N.
Chicagolooper
