Adding numbers to a lot of things in AutoCAD
I am looking to number a lot of things like - 001,002,003 etc
Is there a way to do this without adding the numbers in individually ?
@Anonymous
john.vellek has edited your subject line for clarity: Adding numbers to a lot of things
AllenJessup
Look into Auto Number in Express Tools.
Allen Jessup
CAD Manager - Designer
john.vellek
Hi @Anonymous,
Are you creating text objects or are you using blocks with attributes or something else?  A little more detail and perhaps a sample file would be helpful in pointing you to an appropriate solution.  @AllenJessupmentioned a built-in tool for incrementing text.  For incrementing attributes or Mtext,  I suggest you take a look in the Autodesk App Store for some addin utilities.
John Vellek
pendean
Community Legend
Community Legend
What things exactly? Someone or something is going to click on these "things" in the order you want and add the numbers, but your post is too vague at the moment for meaningful help.
If you are not sure what these "things" are, post your DWG file and explain how the numbering is to go.
john.vellek
Hi @Anonymous
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
