AutoCAD Forum
DWG to PDF issues
1 REPLY 1
284 Views, 1 Reply
DWG to PDF issues
I currently have ACE 2015 and I need help with the DWG to PDF conversion.  I do it all the time but this drawing has several components on top of each other and I typically WIPEOUT all the components to move them to the BACK or FRONT.   When I create a PDF, everything is visible  and see through down to the DIN RAILs.  How do I avoid this?  Am I doing something wrong?  When I print the DWG it look fine but when you convert it to PDF it looks horrible with everything transparent.  Can someone help?  Thanks in advance.
RBN
1 REPLY 1
dany_rochefort
Hey RBN,
Is this 2d or 3d ? When you mention ACE 2015, do you mean like a special version of Autocad?
Im sure i can help, but i need some more info. Can you upload an image?
Forma Design Contest
AutoCAD Beta
