AutoCAD Forum
DWG to PDF issues
1 REPLY 1
307 Views, 1 Reply
DWG to PDF issues
I currently have ACE 2015 and I need help with the DWG to PDF conversion.  I do it all the time but this drawing has several components on top of each other and I typically WIPEOUT all the components to move them to the BACK or FRONT.   When I create a PDF, everything is visible  and see through down to the DIN RAILs.  How do I avoid this?  Am I doing something wrong?  When I print the DWG it look fine but when you convert it to PDF it looks horrible with everything transparent.  Can someone help?  Thanks in advance.
RBN
DWG to PDF issues
RBN
1 REPLY 1
dany_rochefort
dany_rochefort
Hey RBN,
Is this 2d or 3d ? When you mention ACE 2015, do you mean like a special version of Autocad?
Im sure i can help, but i need some more info. Can you upload an image?
Hey RBN,
AutoCAD Inside the Factory
