Hi, has anyone had the issue where a dwg will not display in the Windows 7 preview pane? I have already checked my Thumbnail Preview Settings in Autocad and preview will not show regardless of which version I save the file as. Folder view setting in Windows is also set to display thumbnails. This is unfortunately the easiest way for me to find certain types of files and the preview in AutoCAD's "Open Drawing" dialogue is actually too small for me to distiguish between files. If anyone can help, it would be greatly appreciated.
*Running AutoCAD Architecture 2014 on Windows 7
Solved by pendean. Go to Solution.
The user having the problem is out today, so I'll have to wait 'til Monday to have her try it. But...
I looked at my registry and I'm finding ACAD-B005:409, not ACAD-B001:409. Would that be the same thing? Will this affect the ability to see previews in Windows Explorer? Because while I can see the previews even in explorer, she can't see them anywhere.
This is a tip from a customer with the same problem:
- Check that next key in the registry is setup = 1:
KEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409\Profiles\your profile\Dialogs\Select File - PreviewVisible =1
If it's already = 1, turn it to "0" (zero), launch AutoCAD, run the open command (the preview area should not be visible). Close AutoCAD, and change the value of the key back to "1". Is now the preview available?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
The problem might be in here:
As in, the cad objects are on the Defpoints layer? I wish it was that simple. I'm saying, all files, no matter what they contain, will not display in the Windows 7 Preview Pane.
How does one check their registry?
For the record, my files do show a preview when I'm using the AutoCAD "open new file" dialogue to open them. It's just when I'm opening files through Windows Explorer that there is not thumbnail or anything in the preview pane.
Huh? I asked you how to check the registry. I don't know how to perform the actions you described. The other post was in reply to Patchy.
Yes, I saw that one too upon Googling before this post and do not want to install Drawing TrueView as it has caused problems with my system before.
Note: You can open Registry Editor this way in any version of Windows that utilizes the registry, including Windows 10, Windows 8, Windows 7, Windows Vista, and Windows XP.
Difficulty: Easy
Time Required: It'll take less than a minute to open Registry Editor in any version of Windows.
How To Open Registry Editor
regeditand then press Enter.
Ok, just did this and it did turn off/on the preview function in AutoCAD's "Select File" command but it had no affect on the Window Explorer Preview Pane which is where I'm having the problem.
So it's not a registry or temp issue. It must be settings through AutoCAD or Windows.
Is your AutoCAD file DWG?
I believe it was default as I never changed it and have had a new AutoCAD suite installed a couple times.
I don't have an option for "SHOW CONTROLLERS...". I do however have "Show preview handlers in preview pane" and it is checked.
