AutoCAD Forum
Dual Monitor Support
25 REPLIES 25
Message 1 of 26
40352 Views, 25 Replies
I feel that most of us use dual monitors for our CAD stations. Will AutoCAD ever support more dual monitor goodies like docking, using both screens, etc?
Thanks.
25 REPLIES 25
Message 21 of 26
Alfred.NESWADBA
in reply to: aholman
>> when you got to lunch or your monitors kick into power save mode
>> the AutoCAD shrinks back to 1 monitor
First ... it's a Windows question as Windows informs the applications that one monitor is unplugged and to avoid invisible dialogs the applications are restricted to monitor 1.
BTW: I would never let AutoCAD AND it's working files open when I leave the workstation. Energy saving modes can create more isses than just swap to display 1.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 22 of 26
Hi! If you are using a Windows system, try opening one of your cad file. Once it's open, find the Autocad App in your desktop or in the start apps section, right click the icon/app then click "Run as administrator" then open a file on that window. Then you have 2 operating Autocad XD
Please let me know if you have an alternate solution for this.
Message 23 of 26
robbar30
I Agree with Chauhuh,
What if you have different resolutions, also the docked toolbars get all jackep up when you stretch across screens. Not to mention the issues with viewports. AutoCAD really needs to follow MicroStation's example. They have had true dual monitor support for decades, andnd why stop at two. AutoCAD you are really dropping the ball here.
Message 24 of 26
RobDraw
Posting your opinions here is not going to get them heard by Autodesk. This is a user help forum. Product feedback belongs elsewhere.
Rob
Message 25 of 26
chad_miller
Has AutoCad still not resolved this issue after 7 years of requests by the workforce to comply with the use of multiple monitors?  I don't think anyone in the Engineering world is using a single monitor anymore.  How hard is it to update the program so that dwg. tabs can be opened on another display?
Message 26 of 26
pendean
in reply to: chad_miller
Huh??
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-A7AE85AA-53B6-4AB4-A59C-F10E21DD8404
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-E90A61DB-71FB-4B5F-96B3-223526F26189
https://forums.autodesk.com/t5/autocad-forum/dual-monitor-support/m-p/6334952#M125077
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Dialog-box-positio...
Forma Design Contest
AutoCAD Beta
