AutoCAD Forum
Drawing Settings to verify/reset zone, units, scale, datum, projection etc.. not available in AutoCAD25 trial version
7 REPLIES 7
Message 1 of 8
rcheruvu13
360 Views, 7 Replies
How to invoke "Drawing settings"- screen with the options of setting/resetting the units, scale, zone, transformation, object layers, abreviations, ambient settings - in AutoCAD25, as the ESRI Map geographic location failed to superimpose the drawing already done on WCS scale. So we want to verify and reset the settings of the drawing to match with the ESRI Map settings viz., Datum WGS-84, Projection UTM Zone 44N, scale 1:1000 etc. Earliest guidance is appreciated on how to check/reset the drawings settings.
7 REPLIES 7
Message 2 of 8
cadffm
in reply to: rcheruvu13
nothing to do with the Trial-license, just another Software.
Why do you test AutoCAD, instead Civil3D?
Sebastian
Message 3 of 8
rcheruvu13
in reply to: cadffm
Out of all available Apps, AutoCAD seems satisfying the user requirements
with assured quality, hence using for drawing FMB sketches to claim our
lost extents in recent govt. land resurvey. Kindly guide us as stuck up in
verifyiing/resetting the zone, scale, datum etc... best regards....
Message 4 of 8
Pointdump
Hi @rcheruvu13,
As Sebastian says, you need either Civil 3D or Map 3D to assign a coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 5 of 8
rcheruvu13
in reply to: Pointdump
Are the options of geolocating with Civil 3D, Map 3D possible with trial
version, please guide....regards.
Message 6 of 8
Pointdump
@rcheruvu13,
"Are the options of geolocating with Civil 3D, Map 3D possible with trial version..."?
Yes, trial versions are 100% functioning.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 8
TomBeauford
While Civil 3D cost a good bit more Map 3D has all the mapping functions you're looking for and is a free ad-on to AutoCAD.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 8 of 8
rcheruvu13
in reply to: TomBeauford
Thanking you Sirs.....
Forma Design Contest
AutoCAD Beta
