How to invoke "Drawing settings"- screen with the options of setting/resetting the units, scale, zone, transformation, object layers, abreviations, ambient settings - in AutoCAD25, as the ESRI Map geographic location failed to superimpose the drawing already done on WCS scale. So we want to verify and reset the settings of the drawing to match with the ESRI Map settings viz., Datum WGS-84, Projection UTM Zone 44N, scale 1:1000 etc. Earliest guidance is appreciated on how to check/reset the drawings settings.
nothing to do with the Trial-license, just another Software.
Why do you test AutoCAD, instead Civil3D?
Sebastian
Hi @rcheruvu13,
As Sebastian says, you need either Civil 3D or Map 3D to assign a coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
@rcheruvu13,
"Are the options of geolocating with Civil 3D, Map 3D possible with trial version..."?
Yes, trial versions are 100% functioning.
Dave
Dave Stoll
Las Vegas, Nevada
While Civil 3D cost a good bit more Map 3D has all the mapping functions you're looking for and is a free ad-on to AutoCAD.
