This might be really simple and I can't see it.. I am still learning.
But I have my units set in mm. when I go to draw a line and type in 90 (mm) it comes in as 9000mm. when I draw a line and type in 0.09 in comes in as 90mm.
Its really annoying. Anyone know how to change these settings?
Solved by imadHabash. Go to Solution.
How come ?!! when your input value 90mm , it will draw a line with 90mm total length . would you show us a screencast please ?
Imad Habash
Hi Dimity,
Please use Command -DWGUNITS to check your units.
Dave
Dave Stoll
Las Vegas, Nevada
@dimity.vandiermen wrote:
.... when I go to draw a line and type in 90 (mm) it comes in as 9000mm. when I draw a line and type in 0.09 in comes in as 90mm. ....
How are you determining that it "comes in as" the wrong length? Selecting it and looking at the Properties palette? A LIST command? Or [my guess] by drawing a Dimension, in a Dimension Style that has a multiplier on the measured distance?
Hi Dave,
I have tried -DWGUNITS a few times and hasn't made a difference..
also changed in Drawing utilities - units as well.
If you see the screencast - the settings I have applied and then drawing a 90mm line comes in as a 90000mm when I dimension it...
I then draw a line and typed in 0.90 and it came in as a 90mm line when I demission it ...
Anyone had this issue before or knows how to fix?
please see screencasts, thank you..
Hi Kent, I dimension the line to see the length..
What does the applicable Dimension Style definition have for a linear scale factor? And if you just select the Line and look at its Properties, or select it under a LIST command, is the length correct?
It does say 90 in properties anf in LIST command.. (the proportion looks incorrect)...
though what do you mean by -applicable Dimension Style definition have for a linear scale factor?
Since the units are set correctly for the drawing, cross-check if there is a scale factor set in dimension style.
Change the measurement scale of the current dimension style.
I assume you mean the one you intended to draw at 90 units long is the one that does say 90 [not the one you tried drawing at 0.09]. But I'm curious about what proportion you say looks incorrect.
The image from @Dhananjai_Gopika is what I was talking about. I am guessing you had a scale factor of 1000 there.
Another check you can do is to use either the DIST command or the MEASUREGEOM command and its Distance option, and check the distance between the Line's endpoints.
