Drawing is somehow Xrefed into itself
Message 1 of 65
I am currently working on a drawing and just relaized that it is somehow Xrefed into itself and I am unable to detach it.  Any thoughts?  Thanks in advance.
S.Clancy
Replies (64)
Message 41 of 65
Apologizes, I have not had the chance to attempt the method in your last reply.  I did however get a free second to try the copy/paste method and the Xref did in fact disappear.  This did not happen when I attempted the WBLOCK method twice earlier when first suggested by Alfred.  That being said,  I would still like find a more viable solution to this problem, so I will attempt your suggestions in last post when I get a free moment and let you know if it was successful.  Appreciate all the help.
-S.Clancy
Message 42 of 65
RobDraw
Deatach all the other XREFs then erase eveything. If the XREF in question is still not able to be detached, use Ctrl+A to see if you get multiple instances of that XREF.
Rob
Message 43 of 65
Didn't work, still unable to detach.
Message 44 of 65
RobDraw
I'm trying to find out if there are multiple instances that cannot be seen for some reason. I didn't say to detach. Just check to see if there are multiple instances, if it is not visible. If there are then erase them and you will be able to detach afterwards.
Rob
Message 45 of 65
Understood, but still no visible attributes.
Message 46 of 65
RobDraw
Maybe it is not visible, that's what I'm trying to determine.
Let me try to explain it another way.
Detach all of the other XREFs.
Make sure all layers are on and thawed.
Delete everything visible. Select using a window or crossing window.
Use Ctrl+A to select everything that is left (not visible).
If there are multiple instances of the XREF in the selection set, delete them.
You should now be able to detach it.
Rob
Message 47 of 65
rkmcswain
And to add to that, the command DBLIST will list everything in the drawing, including invisible entities.
Once you think everything has been erased, run the command DBLIST and take a look.
Message 48 of 65
RobDraw
DBList is a good one. I've always used Ctrl+A and the properties box to find out what is left.
Rob
Message 49 of 65
Did the DBlist, nothing left, still cannot detach.
Message 50 of 65
rkmcswain
Was curious, and did the Ctrl+A then Props. It works too.
Good to know also 🙂
;;; make invisible
(vla-put-visible (vlax-ename->vla-object (car (entsel))) :vlax-false)
Message 51 of 65
RobDraw
How about if you purge that "empty" drawing.
Rob
Message 52 of 65
Alfred.NESWADBA
Just to add: <CTRL><A> only selects objects in the current space, so if you are in modelspace, but the XRef is attached to the paperspace of any layout <CTRL><A> would not select it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 53 of 65
RobDraw
Good point. I was assuming the XREF of a building would be in model space. It could have been inserted (scaled down) as a keyplan in paperspace.
Rob
Message 54 of 65
rkmcswain
Congrats @Anonymous - I think this is the biggest mystery on the forums I've seen in years.
Message 55 of 65
RobDraw
It's a mystery because we don't have a file. We all are guessing.
Rob
Message 56 of 65
rkmcswain
Maybe OP wants to snoop the db....
https://twitter.com/cadpanacea/status/697454846153101312
Message 57 of 65
And I sincerely appreciate all the help and I wish I could upload the drawing but given the sensitvity, I am unable to do so.  That being said given my experience along with all of you fine gentlemen,  we would have most certainly solved this already if it was a semi "normal" problem. But, thanks again.
Message 58 of 65
RobDraw
Couldn't you upload it without the sensitive information? Say that "empty" file that the XREF cannot be detached from.
Rob
Message 59 of 65
That I can do....
Edited by request
Discussion_Admin
Message 60 of 65
....that is actually the original file with everything removed.
