Draw Order in 2019 Not Working
jserrato25YGE
Message 1 of 102
jserrato25YGE
I'm using AutoCAD 2019. In paper space, I inserted an image that will have text and objects in front of it. When I select the image and change the draw order to be in the back, it works, but as soon as I change tabs, it goes back to being in the front. I've never had this problems in previous versions. Any ideas on why this is happening?
Accepted solutions (3)
Replies (101)
Message 41 of 102
pendean
Community Legend
Community Legend
All updates for your software are in your Autodesk Account page, go help yourself https://manage.autodesk.com/
Message 42 of 102
How many people feel that if AutoDesk actually fixed the draw order command, that it would save them hours amounting in the 100's per year?  And also, that you would rather have AutoDesk fix problems like this, that have been around for a long, long time, than for AutoDesk programmers to spend time working on "New Features"?
Message 43 of 102
Well, I have installed at least 2 updates that were supposed to fix this issue - alas and yet it remains.  Anything else?
Message 44 of 102
Alfred.NESWADBA
Can you please start command _ABOUT and show us a screenshot from that dialog?
When you try the draworder functionality, have you tried it in new drawings too?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 45 of 102
Hi Alfred,
The issue seems to have been resolved by some of the updates since I posted that comment.
Thanks.
Message 46 of 102
So.  What I really think is that you should be able to assign the order of specific layers in the Layer Dialog.  And, you should have - let's say 10 levels of visibility control.  So you can actually control the order in which layers display.  When I have an Xref drawing - at least for me - many times I NEVER want it to plot over the top of my current drawing layers.  If I reload it or move it - still - I never want it to plot over any other layers.  Why is this so tough?
Message 47 of 102
Has this issue been resolved? It has NOT been fixed for all drawings. We have multiple users who have ALL of the updates installed and this is still an issue with some drawings. With some drawings, it seems to happen when plotting/publishing and some its only when publishing. Some drawings are even affected when closing/reopening the drawing. Most of the issues are with the hatching.
We have purged and audited the drawings. Some variables mentioned in other forums were checked (TREEDEPTH = 3020, DRAWORDERCTL = 3, WHIPTHREAD = 1). We tried publishing in both the foreground and background.
All machines have the following info in ABOUT:
Product Version: 13.0.1175.0 Civil 3D 2019.2 Update
Built on: P.162.0.0 AutoCAD 2019.1.2
                22.0.022.16 Autodesk AutoCAD Map 3D 2019.0.1 Update
                8.1.48.0 AutoCAD Architecture 2019
Any thoughts would be appreciated.
Jeremy Borgman
Message 48 of 102
cadffm
You forgot SORTENTS
And: If you talk about a file depend problem, why do you not upload a problem in kind of a dwg?
Perfect is a dwg with just 2-5 objects and you explaining what is wrong and not changeable (or still a problem after reopening).
Sebastian
Message 49 of 102
jbernal
We are experiencing the same issues. I have the same updates as @Anonymous and have used the same settings. Attached is one of our files. I have tried the draworder update, and when I open the file it's back to showing on top. I have used the treedepth = 0 and it all works fine, till I open the file and the images are back on top. I also tried to detach and re-attach an image but no luck, this would be a pain anyways as there are many drawings and many images and each image has image clips that would have to be re-done too.
Message 50 of 102
This failure is a huge time waster - you can't rely on what you see in the paperspace viewport - you will only know after you plot and see.  The most reliable thing I have found is to move the block or xref some distance,  then make a new instance from a copy and put it back into position, run the display order and then try to replot - see what you get.  That is the most successful approach I have found.
This "feature" in Autocad is vital to publishing - there should be several, reliable ways to set display orders in a drawing file - by Xref, By Layer, etc. By today's state of the art publishing - this is remedial.  AutoDesk is way, way behind the curve.
Message 51 of 102
cadffm
Hi @jbernal ,
images are very special and you need the high quality graphic feature.
Q: Is your HQGEOM turn on and you have trouble? Please set it to ON and try it again.
Sebastian
Message 52 of 102
Could try turning off "Hardware Acceleration", solved my hatch display order problem.
Message 53 of 102
I am having the same issue but I am using
Civil 3D 2018.3 Update
AutoCAD 2018.1.2 Update
AutoCAD Map 3D 2018.0.1
Arcitecture 2018
Yesterday I switched profiles and then switched back and it resolved the issue but today that doesn't even work.
Your Favorite Minion Bob!
Message 54 of 102
tcorey
@Anonymous wrote:
... This is nothing but free advertising for Solidworks.
Because SolidWorks has no defects?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 55 of 102
Making a copy, erasing the original and putting the copy back in place seems to be a reliable work-around. Set the display order after you copy (usually it is a “background entity or xref that I am dealing with). Totally annoying and seriously time wasting - wish they would just fix it.
Message 56 of 102
cromo23
2020 has the same issue by the looks
Message 57 of 102
jbokic2F9MM
I've had to do that twice in the same drawing between editing sessions, to do it every time I open a drawing would be impractical (especially with more complicated drawings).
I've recently started running Civil 3D 2019.3.1 (AutoCAD 2019.1.2 and Map 3D 2019.0.1) which is having this problem, will likely go back to 2018 and hope I don't have the same problems as Minion Bob.
Message 58 of 102
The hotlink is no longer available and I am still battling this issue. I've changed DRAWORDERCTL to 0-3. Setting at 2, this will temporarily fix allowing me to plot my project. I'll move things above another object and switch tabs, and come back and it will have reverted back. But particularly, images seem to jump the worst to the front. I need a forever fix. Any other suggestions?
Message 59 of 102
cadffm
The hotfix is included to the newest update, you don't need this.
Update your program to 2019.1.2, thats all.
Images are a special thing, what you can test: Graphicsconfig HA ON or OFF, try both.
Perhaps  the graphic card/driver/setting  is a problem in this case.
Variables: Use the default values, [F1] says 127 and 3.
Underlays an Images in DWGs.. only if there is no other way.
There is no alltime solution.
Sebastian
Message 60 of 102
bham4ever
This has been a problem since the beginning of Draworder.
No one has a perfect solution, I am using C3D2020 and every time your drawing gets bigger the worse the problem. Esp for model space views in paperspace. Guess it needs to be on everyone's wish list.
"Never say Never"
