AutoCAD Forum
Draw Order Autocad 2022 Not showing properly
2 REPLIES 2
mbootsUJVFW
267 Views, 2 Replies
I'm working in AutoCad 2022 and have a bunch of photos that are showing behind linework, even after using draw order to bring to front. However, when i go to plot, they show up in front like what i want, they only don't show up correctly when working in the paper space. Do i have some weird setting enabled, or is this a bug?
Labels (1)
2 REPLIES 2
Valentin-WSP
in reply to: mbootsUJVFW
@mbootsUJVFW ,
Follow the suggestion from this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
pendean
@mbootsUJVFW
Have you installed the 2022.1.3 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
Forma Design Contest
AutoCAD Beta
