Draw Order Autocad 2022 Not showing properly
McKinleyBoots
McKinleyBoots
I'm working in AutoCad 2022 and have a bunch of photos that are showing behind linework, even after using draw order to bring to front. However, when i go to plot, they show up in front like what i want, they only don't show up correctly when working in the paper space. Do i have some weird setting enabled, or is this a bug?
Valentin_CAD
@McKinleyBoots ,
Follow the suggestion from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
@McKinleyBoots
Have you installed the 2022.1.3 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
