When I click to edit a viewport in AutoCAD in layouts, so I can scroll and pan my drawing to the correct view and size. It takes me to a model space page where this comes up:
Then nothing happens. I then quit this with pspace command to return to my layout containing my unsuccessfully edited viewport :/.
What am I doing wrong. I have 3 detailed viewports on my layout, I don't imagine this is a Hardware issue as I have 32GB of RAM? I am using AutoCAD 2017.
Thank you
Solved by DavidPTTLG5. Go to Solution.
If you click on the edge of the viewport it will take you to model space zoomed in on that viewport. It's handy if you don't want to have to locate something in model space especially if you are working on someone else's drawing that are a mess. If you click in the viewport not on the edge it takes you into modelspace in that viewport but still on the layout tab. That is what you want to do.
Nick DiPietro
Cad Manager/Monkey
A double click on the VP will place you in MS in a maximized viewport view. If you want to edit a VP just click once and then proceed with your edit. If you want to go into MS through the viewport then double click over the viewport area and not directly on the VP border.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I see! When I do this, it selects the main large viewport rather than the small detailed ones. So I can't seem to edit them? Can only click on their boarders to edit in model space.
I have figured it out, I needed to create a new layer. AutoCAD didn't seem to like that the viewports were on layer 0!?
Sebastian
THIS STILL DOES THE SAME THING FOR ME, AND MY VIEWPORTS ARE ON A NOPLOT LAYER.
THEY NEED TO ADJUST THE TIME TO RECOGNIZE CLICKS. THIS IS SUCH A PAIN. I HAVE TO RIGHT CLICK AND EDIT ATTRIBUTES BECAUSE DOUBLE CLICKING TAKES ME INTO THE MODELSPACE VIEWPORT EVERY SINGLE TIME. THEY NEED TO UNDO WHAT THEY CHANGED SINCE LAST VERSION. THIS IS A REAL PAIN.
@DavidPTTLG5 wrote:....THEY NEED TO UNDO WHAT THEY CHANGED SINCE LAST VERSION...
May I ask, how long back a version of AutoCAD did you use? double-clicking to enter a viewport have been around for a very very long time now.
Or by chance did you just forget to reset this old variable to what you need it to be like you did last time with your older version
Thank you,
When did that variable come in? I have only had this happen in 2024 ACA.
I wish they wouldn't turn on things that were previously always off.
@DavidPTTLG5 wrote:...When did that variable come in?...
SPACESWITCH the variable? the year 2004 is the earliest documentation I can find right now, 20+years ago.
@DavidPTTLG5 wrote:....I wish they wouldn't turn on things that were previously always off.
Hardly. The core default is ON for over 20-years now, aka what you don't want, so you must have never known about it or someone took care of it for you before today that you never noticed before now
And so on, you get the picture.
Wow, I forgot I posted even posted this all those years ago. If memory surveys me right, i was having this issue when my UCS in the layout page wasn't set to world. Try setting the UCS back to home in your layout, I think that's what solved my problems problem when I posted this.
I have been using AutoCAD for 30 years and I am usually the one doing the installation.
While working on a project, I upgraded to 2024, and this started happening. I have never needed this setting changed until ACAD 2024. Those are the facts. I noticed a bunch of other things that are now turned on that I have to research and figure out what variable I have to change.
In this case, my only explaination is:
You used the "migrate from previous version" feature.
This feature CAN do unwanted things and CAN set up IMPOSSIBLE settings (in all versions).
You can see the default values in your help[F1] and they are correct for a new ootb installation.
Sebastian
Okay, that means we don't know how it came.
Deinstall/Reinstall or reset to default,
I bet the settings are as expected.
Like you: Never had or read about such behaviors, except someone uses migration tools.
Also not in 2025
Sebastian
@DavidPTTLG5 wrote:...While working on a project, I upgraded to 2024...
Never should have done that. Sorry.
@DavidPTTLG5 wrote:I have been using AutoCAD for 30 years... and this started happening....
Cant help you there, a stock default setting in the program is what it is. OOTB proof was provided in my last reply.
Since we are all old-timers around here just like you with 20-30-40years experience in the AutoCAD/variants, we all have our favorite variables saved as scripts and LISP to reactivate and reset all the time to best fit our needs when we change. And for many versions of AutoCAD now, SYSVARMONITOR command helps keep those variables changes only a notification away if and when they change. Looks like you are ready to start implementing more control on your environment that ever before: let us know if you need help creating these.
Best wishes.
I only use AutoCAD for about 1% of my work. I mastered Autodesk Architecture but I have been using Revit almost exclusively for the last 15 years. I run into many things that are different out of the box. I have even seen direct installs be configured differently from a direct install vs a download manager install.
I last time I used AutoCAD full time I was using ACA 2004, so there are a bunch of little changes that really tripped me up because my usual rhythm was interrupted. Things like the insert dialog change to the pallet. I will always hit I to insert. I have remapped it to the classic insert dialog. I like the block pallet for standard-specific stuff like Coast Guard and school work. I have just grown to dislike AutoCAD.
Thanks for the input.
I just got around to checking that variable and that is not what I am looking for. I want to be able to double click to get into a viewport when I need to. I do not want to switch to the viewport when I double click on an attributed block. This is what started when I switched to ACA 2024. I never had this happen until I switched to 2024. Maybe I need to adjust the click settings in windows.
I decided to reinstall AutoCAD and the problem went away. Go figure. This computer was set up originally by someone else. I reinstalled and imported my profile and now it is working the way it is supposed to. I still have no idea what caused this.
Well, the fix was only temporary. It was working as it should after a complete reinstall. Now I have to right click and chose edit attributes instead of double clicking. I think it was the last update that makes the change. That is the only thing I did after testing it out. Very frustrating.
