AutoCAD Forum
Double Click Edit Mtext issues
5 REPLIES 5
smaher12
196 Views, 5 Replies
I was able to double click on Mtext and it would instantly go into edit mode. Now if I double click on mtext I need to select the mtext again for it to go into edit mode. Anyone know what variable it is to go back to my original setting?
My current variable settings are the following: What else am I missing?
dblclkedit = 1
pickfirst = 1
5 REPLIES 5
pendean
in reply to: smaher12
Get a new mouse? PC?
Did you restart your PC yet? Always the first thing to try.
Then try the highlighted sections here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Double-click-editi....
smaher12
in reply to: pendean
No new mouse/PC. Yes, the PC was restarted.
Patchy
Try:
QAFLAGS
use Zero
smaher12
You nailed Patchy. Thank you!
Patchy
Technology Administrators
