AutoCAD Forum
Double Click DWG files and Open the Correct Application but Wrong Icon.
3 REPLIES 3
laikuntaoALZN5
438 Views, 3 Replies
laikuntaoALZN5
My computer has installed both "AutoCAD 2023" and "AutoCAD Map 3D 2023".
After double-clicking the dwg files, I found the AutoCAD 2023 was openning, but the taskbar icon was shown as the AutoCAD Map 3D 2023 application.
How could I fix it? Thx for help!
Labels (2)
3 REPLIES 3
pendean
in reply to: laikuntaoALZN5
pendean
Community Legend
Community Legend
What does the program window look like when it is fully open, do you see plain AutoCAD or Map3D? that might explain your query here better for us.
Read this from Autodesk if the program that opens in NOT the one you want opened https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Double...
laikuntaoALZN5
in reply to: pendean
laikuntaoALZN5
when it is fully open,the plain autocad shows up. however, the taskbar shows the map3d icon.
pendean
pendean
Community Legend
Community Legend
The program that opens is all that matters. Try going through the link I provided to you from my earlier reply to that Autodesk document to fix files associations, then you need to open MAP first, open your DWG file, confirm it is all working, QSAVE and close that file then close the program, then test it all again by double-clicking on a DWG file.
yes it is a long process, this is your computer and you will need to configure it to work correctly since it appears Autodesk failed to do so.
AutoCAD Inside the Factory
