My computer has installed both "AutoCAD 2023" and "AutoCAD Map 3D 2023".
After double-clicking the dwg files, I found the AutoCAD 2023 was openning, but the taskbar icon was shown as the AutoCAD Map 3D 2023 application.
How could I fix it? Thx for help!
Solved by pendean. Go to Solution.
when it is fully open,the plain autocad shows up. however, the taskbar shows the map3d icon.
The program that opens is all that matters. Try going through the link I provided to you from my earlier reply to that Autodesk document to fix files associations, then you need to open MAP first, open your DWG file, confirm it is all working, QSAVE and close that file then close the program, then test it all again by double-clicking on a DWG file.
yes it is a long process, this is your computer and you will need to configure it to work correctly since it appears Autodesk failed to do so.
