Is there any way to perform dome on a face?
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
I think there are several ways to create a dome.
You can either use, REVOLVE command or LOFT command. see below videos for your reference.
Hope this is helpful. thanks
Am I correct that the "face" in question is not circular? [A circular face could have a SPHERE built on it, and SLICEd in half.] If it's elliptical, see >this<.
You are right. It's not circular rather spherical.
RUET
Thank you.
I meant the face that you want to build a dome onto -- "circular" is a 2D characteristic, but "spherical" is a 3D characteristic. In the image, it looks like the cross-section of what I assume is something like a mug handle is not circular, so the flat face on the end is not, either. If that's right, and if it's an elliptical cross-section and face, it would mean you don't want a half-sphere on the end of it, but a half-ellipsoid [see the link in my previous Reply to learn how you can make that].
You could make a SPHERE, SLICE it in half, define the half-sphere as a BLOCK, and INSERT it on the face using different scale factors to make it elliptical. But then you would not be able to join it as a 3D Solid to the handle or the mug with UNION, because you can't EXPLODE a Block containing a 3D Solid if its scale factors are not equal.
