Warp Image to Common Points?
Message 1 of 9
In Microstation there is a warp command that move, rotates, scales, and warps and image based on known locations.  Is there anything like that in AutoCAD?
I have a bunch of utility images that I want to quickly orient on a road to trace right into my drawing.
Replies (8)
Message 2 of 9
Patchy
If you use Map or Civil3d you can use Rubber Sheet, or buy Rater Image from Autodesk.
Message 3 of 9
dgorsman
AutoCAD Raster Design plug-in has the Rubbersheet command.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 9
Todd_Rogers
He means Raster Design.  It's ok @Patchy, it's ALMOST Friday! Smiley Wink
Todd Rogers
Civil Administration at Walter P Moore
Message 5 of 9
edwin.prakoso
Do you want to use it as underlay or as rendering background?
I know in Ustation you can define points to resize and locate the image to match your 3D model.
Cheers,
Edwin Prakoso
Message 6 of 9
Thanks for the input guys.  Yeah, I was looking for a solution that wouldn't cost me anything so the raster plug in is probably a no go.  Also, it was just better to insert, move, rotate, and scale.  I was just hoping for a faster method.  Thanks!!
Message 7 of 9
dgorsman
FYI - Raster Design is included in most of the AutoCAD-based suites.
Message 8 of 9
ADERSHEET
Message 9 of 9
awhiteQ38RQ
This is the command that worked for me in Civil3D! Thank you!!
