Solid Triaxial Ellipsoid in 2021
Is there a way to generate a SOLID triaxial ellipsoid that can be scaled, and have Union and Subtraction performed on it?  I have tried blocking out a solid sphere, inserting it after scaling the three axes, and I keep ending up with an object that cannot be manipulated.
Replies (8)
leeminardi
To create a solid triaxial ellipsoid you can start with a box with the overall dimensions of the ellipsoid and create an ellipse on each of the 3 principal sides.
Center the ellipses within the box and cut two of them in half (indicated below by different colors, magenta/red for one of the split ellipses, yellow/green for the other).
Give the LOFT command and select the green, then magenta, the yellow, the red ellipses and hit [Enter] then enter G (guides) and select the full cyan ellipse. This will yield a surface object.
Finish by giving the surfsculpt command and select the model to convert it to a solid.
Note, you may need to change the visualstyle to shaded to see the solid shape.
lee.minardi
Thank you very much!  This was just what I needed to prepare some geodetic models.
leeminardi
You are welcome. I can see using an ellipsoid in a geodesic model but not sure how in a geodetic model.
lee.minardi
Briefly, geodesy is the entire science of the size and shape of the earth, and the relationship of points on it, as well as the gravity field. A geodesic is typically a line on an ellipsoid. Thanks again, Bryan
loulouv18
Hi, I'm also trying to create a tri-axial ellipsoid but in Inventor. My issue is that I don't know how to make the ellipses arc coincident when they are supposed to cross each other.  Trying your suggested method also didn't work for me because once I have the 3D box (created in 3D sketch) I am not sure how to make the ellipses on the same sides of the box. Would anyone be willing to help me? Thanks!
Loulou
pendean
Community Legend
Community Legend
The INVENTOR forum is over here https://forums.autodesk.com/t5/inventor-forum/bd-p/78
If you want others to look at this post for reference then just add a link to it in your post over at Inventor' forum.
HTH
cadman777
I saw this in the Inventor forum.
I'm an Inventor user.
Here's a tip when using Inventor:
It doesn't work like AutoCAD (before Inventor, I was a long-time AutoCAD user).
So you have to approach modeling differently in Inventor.
Hope this helps.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
chasbosc
Community Visitor
Community Visitor
I can't begin to thank you enough for this solution!!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
