DISPLAY ERROR WHEN MOVING PANELS
NGUYENVANTOAN_CXCKPT
Message 1 of 10
When I move the properties panel or any other panel, the AutoCAD screen displays dots like a matrix. I have tried all AutoCAD versions, but the issue persists. I have checked the screen configuration, reset AutoCAD, reinstalled windows, but the problem still remains. Can you help me?
Replies (9)
Message 2 of 10
CGBenner
@NGUYENVANTOAN_CXCKPT
Welcome to the Community.  This looks like a problem with either your graphics adapter, or possibly even your monitor itself.  Can you describe your hardware for us?  What kind of computer are you on, graphics adapter, OS etc.
Chris Benner
Message 3 of 10
imadHabash
Try to disable hardware acceleration from GRAPHICSCONFIG command.
Imad Habash
Message 4 of 10
paullimapa
Try setting Gfxdx12 to 0 (that’s zero) then close and restart AutoCAD.
Paul Li
IT Specialist
@The Office
Message 5 of 10
Xin chào CGBenner
I send you the hardware information I am using
Thank you, have a
Thank you, have a nice day
Message 6 of 10
Hi  imadHabash
I turned off hardware acceleration. But it didn't fix the problem.
Message 7 of 10
Hi paullimapa
I set Gfxdx12 to 0 (i.e. zero) then closed and restarted AutoCAD but that did not fix the problem.
Message 8 of 10
paullimapa
Message 9 of 10
hi paullimapa
I am using autocad version 2024 and 2025
Message 10 of 10
paullimapa
your computer's graphics card may just not be compatible with 2024 & 2025:
Solved: Can't enable hardware acceleration - Autodesk Community
Maybe try rolling back the graphics card driver or see if there's an updated driver to see if any of this would make a difference.
Paul Li
IT Specialist
@The Office
