Hello guys,
I have a problem with a autocad file : Autocad crashed and when I have tried to re-open the file, all of spline have disappeared. I had try to regenerate, to recover the file extension .bak, ... but I have no succeed ...
If someone can find a solution, it can help me ... Thank you
Solved by imadHabash. Go to Solution.
>> Autocad crashed and when I have tried to re-open the file, all of spline have disappeared. <<
if you don't save the file then you won't get your unsaved work. i suggest to search in your temp folder and look there . C:\Users\(your user name)\AppData\Local\Temp .
Imad Habash
I haven't find my temp folder but I have in my trash a recovered file with the extension .tmp, it can help me ?
Regards
>> I haven't find my temp folder .... <<
you have to change an option from the Tools when you open windows explorer ( see below image ) please come back and try again to check the same path in my first post.
Imad Habash
I'm sorry but I work on a Macintosh so I don't know how to change the option ...
>> I'm sorry but I work on a Macintosh so I don't know how to change the option ... <<
Mmmm ... the idea was to take the .bak file from that folder . it's help me in many previous cases.
Imad Habash
I have try to get back the file .bak but when I open it I have the same problem ...
Have you got an other idea because I don't understand the problem and I really need to work on the file ... ?
when you lost your all of spline... have you save your dwg file ? if yes then it's there BUT if not then as i said to you that you won't get it . if do you want to share your dwg file i'm glad to take a look .
Imad Habash
I save regularly my file when I work on it. Thanks a lot for your help, I join my file ...
What's really strange it's that in the logo file we can see the disappeared spline ...
since i don't know where to look in your crowded dwg . I've just turn ON all layers and i found some splines. see attached file
All the best...
Imad Habash
Thanks a lot you have save my day. If you can just explain how you do, I want understand ...
Thanks a lot again
>> Thanks a lot you have save my day. <<
cool ... glad to hear that. :0
all the best...
Imad Habash
Can you just explain me how you do, it help me to understand what was the problem ...
Thanks a lot
yes of course ... i just Purge and Audit the drawing then i turn ON all layers. honestly that all what i do.
Imad Habash
