AutoCAD Forum
Disappeared line
17 REPLIES 17
Message 1 of 18
809 Views, 17 Replies
Disappeared line
Hello guys,
I have a problem with a autocad file : Autocad crashed and when I have tried to re-open the file, all of spline have disappeared. I had try to regenerate, to recover the file extension .bak, ... but I have no succeed ...
If someone can find a solution, it can help me ... Thank you
17 REPLIES 17
Message 2 of 18
imadHabash
>> Autocad crashed and when I have tried to re-open the file, all of spline have disappeared. <<
if you don't save the file then you won't get your unsaved work. i suggest to search in your temp folder and look there . C:\Users\(your user name)\AppData\Local\Temp .
Imad Habash
Message 3 of 18
in reply to: imadHabash
I haven't find my temp folder but I have in my trash a recovered file with the extension .tmp, it can help me ?
Regards
Message 4 of 18
imadHabash
>> I haven't find my temp folder .... <<
you have to change an option from the Tools when you open windows explorer ( see below image ) please come back and try again to check the same path in my first post.
Imad Habash
Message 5 of 18
I'm sorry but I work on a Macintosh so I don't know how to change the option ...
Message 6 of 18
imadHabash
>> I'm sorry but I work on a Macintosh so I don't know how to change the option ...  <<
Mmmm ... the idea was to take the .bak file from that folder . it's help me in many previous cases.
Imad Habash
Message 7 of 18
I have try to get back the file .bak but when I open it I have the same problem ...
Message 8 of 18
Have you got an other idea because I don't understand the problem and I really need to work on the file ... ?
Message 9 of 18
imadHabash
when you lost your all of spline... have you save your dwg file ? if yes then it's there BUT if not then as i said to you that you won't get it . if do you want to share your dwg file i'm glad to take a look .
Imad Habash
Message 10 of 18
I save regularly my file when I work on it. Thanks a lot for your help, I join my file ...
What's really strange it's that in the logo file we can see the disappeared spline ...
Message 11 of 18
imadHabash
since i don't know where to look in your crowded dwg . I've just turn ON all layers and i found some splines. see attached file
All the best...
Imad Habash
Message 12 of 18
pendean
What logo? Where in your file?
BTW the MAC forum is over here https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
Message 13 of 18
Thanks a lot you have save my day. If you can just explain how you do, I want understand ...
Thanks a lot again
Message 14 of 18
imadHabash
>> Thanks a lot you have save my day. <<
cool ... glad to hear that. :0
all the best...
Imad Habash
Message 15 of 18
in reply to: pendean
Pendean,
Thank you for your answer but ImadHabash has find a solution.
Regards
Message 16 of 18
Can you just explain me how you do, it help me to understand what was the problem ...
Thanks a lot
Message 17 of 18
imadHabash
yes of course ... i just Purge and Audit the drawing then i turn ON all layers. honestly that all what i do.
Imad Habash
Message 18 of 18
Okay thanks lot, I notice it for the next time
Best regards
AutoCAD Inside the Factory
