AutoCAD Forum
Dimensions change after FLATTEN
3 REPLIES 3
SEC_CAD
2544 Views, 3 Replies
I have modeled an object in AutoCAD 2009 in 3D space. From this I want to create dimensioned projection drawings so I apply FLATTEN to my model. All of the dimensions in the flattened drawing are slightly out e.g. 65.6 mm become 65.56 mm. (This is not a dimensioning precision issue).
How do I ensure that my flattened drawing is dimensionally accurate?
3 REPLIES 3
WarrenGeissler
in reply to: SEC_CAD
Do NOT use FLATTEN - use FLATSHOT.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
SEC_CAD
in reply to: WarrenGeissler
Thanks. FLATSHOT did the trick.
A bit difficult to use, as it does not allow you to select a single object to flatten but flattens the entire model space.
WarrenGeissler
There are a few other commands (SOLVIEW, SOLDRAW) I couldn't think of last night. You can look them up >>HERE<<
Warren Geissler
Forma Design Contest
