Dimension Text Placement When Text Is Not In The Default Position
This seems to be an issue that seems to have gone un-resolved for many years. I've seen posts on various forums dating back to 2015. I'm using 2024 and I'm still unable to find any system variable or a workaround for this problem.
I have attached a screenshot that shows the Modify Dimension Style Dialogue Box. Under the "Fit" tab there is an option at the bottom for text placement when not in the default position but there is no option to enter a distance. In the example beside the dialogue you will see that when the dimension text does not fit between the lines it jumps away from the dimension line quite a significant distance. This is clearly not ideal as I then have to pick and drag every rogue bit of text back toward the dimension line.
Has there been a fix for this that I am unaware of?
