Text Size
Text Size
adrek_mahlenbrock
Message 1 of 8
Text Size
adrek_mahlenbrock
Whenever using text in dimensions or in general, the default text size starts at 42 even though I have not changed any of the default text heights. When I try to change the height the text size will scale with what I put in. (If I put in .5 instead of 1, the font will change to 21) Does anyone have any solutions?
Replies (7)
Message 2 of 8
paullimapa
share a drawing with this issue
Paul Li
IT Specialist
@The Office
Message 3 of 8
adrek_mahlenbrock
All settings are default.
Message 4 of 8
adrek_mahlenbrock
Here
Message 5 of 8
pendean
Community Legend
Community Legend
@adrek_mahlenbrock wrote:
Here
There is nothing wrong with your shared DWG file
Did it actually show "42 high" in PROPERTIES palette like I show above, or was that just a guess-timate by counting those tiny little screen squares? If the latter... Turn off GFXDX12 variable (set it to zero), restart your AutoCAD 2025, then your issue should go away.
Message 6 of 8
adrek_mahlenbrock
Thank you so much, it worked.
Message 7 of 8
paullimapa
also make sure you've installed the 2025.1.1 update
Paul Li
IT Specialist
@The Office
Message 8 of 8
al2213040809
Community Visitor
Community Visitor
Thanks a lot! I´ve been strugling with this same problem for the past 3 hours. It worked
