I have a dimension which is part of the block definition.
I created a block reference which refers to the above-mentioned block definition.
In which the scale of the block reference X, Y, Z is 0.0394
and whereas the "DIM scale overall" value of the dimension is 1.
The issue is when I explode the Block reference, the objects(such as line, circle..) sizes are rendered based upon the scale, but whereas the dimension part is getting scaled up and the "Dim scale overall" value still remains 1.
When I manually change Dim scale overall property to "0.0394" of the dimension, then it fits with the objects(Line).
Why is AutoCAD not supporting with the dimension part for the above case?
or
Is there any command or variable which can set both the scales same value.
i.e. Scale X, Y, Z = Dim scale overall =0.0394
Is there a way to get either of these options to work or even a better way to fit the dimension correctly.
Thanks...!
yeah, I have added some more information...
Thanks but I would like to know that is it the bug in the AutoCAD ?
or
Is it "WORKING AS DESIGN" for AutoCAD.
Thanks.
Sebastian
