Different results for Batch Plot vs Plot
dtissellREJTW
dtissellREJTW
I am trying to batch plot a set of plans.  After using the batch plot function I am noticing a portion of the drawing not being plotted.  I am not having this problem when plotting.  I have attached a copy of both types of plots.  I don't understand why the bath plot would have this issue.  Any help would be appreciated.
Alfred.NESWADBA
a few questions to start:
  • which version of AutoCAD are you running, which service pack is installed for AutoCAD (and did you search for newer service packs).
  • which PDF-driver did you use
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
dtissellREJTW
Civil 3D 2015
I'm not sure how the view the service packs I have installed. I have windows 10 and all the instructions I found to view them are for different versions of windows.
I using this driver for the batch plot: Non-System Driver - Autodesk ePlot (PDF) DWG To PDF
Alfred.NESWADBA
Start command _ABOUT, upload a screenshot from that dialog (mask your serial, if there is any).
>> Civil 3D 2015 [...] I have windows 10
Does not mean that this is the source of the issue, but Civil 3D 2015 is no designed to run on Windows 10
Please find >>>there<<< the system requirements.
- alfred -
Alfred NESWADBA
john.vellek
Hi @dtissellREJTW,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am sorry you are seeing this strange issue with Publish vs Plot. Is it possible to eTransmit a few drawings and post the Zip to this thread?  I would like to see if it happens on my side as well.
When you run the Publish, are you applying a named page setup? Or, are you simply using the Publish to: PDF?
John Vellek
dtissellREJTW
Thanks for your help. I found a solution. I regraded the areas that were not printing. Not ideal, but it works.
Daniel
dtissellREJTW
I was using the publish to pdf.  Unfortunately I overwrote the documents.  I found that they would print correctly if I deleted the grading I had and regraded.
