AutoCAD Forum
Different cursor not snapping to points
3 REPLIES 3
baileyargus96
414 Views, 3 Replies
I've opened up Autocad and my cursor has changed for what k was previously using and no is not snapping to points. Does anyone have a fix for this. Object snaps are turned on
Labels (1)
3 REPLIES 3
vinodkl
in reply to: baileyargus96
Try setting AUTOSNAP to "63". Type in command "AUTOSNAP" and set it to "63". Does the object snap work now?
When you say different cursor are you talking about the box aperture box in the center of crosshair after executing a command? To disable the autosnap aperture box, type in APBOX and set it to "0".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
i suggest to check your AUTOSNAP (System Variable) . >> Click <<
Imad Habash
Maybe you mistook the icon for 3D snaps and have that on instead of the regular osnap icon?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Forma Design Contest
AutoCAD Beta
