09:02 AM
When I type 'PO' and press enter, I can only select one point and then AutoCAD exits the command without any Esc or Enter key pressed by me
In contrast when I select the Multiple Points in the expanded Draw panel, I can select as many points I want and then I can exit the command by pressing Esc key
Is there a system variable that causes this difference between PO and Multiple Points? How can I make PO command work like the Multiple Points?
