Anuncios
Difference of PO command and selecting Multiple Points in expanded Draw panel
No aplicable
When I type 'PO' and press enter, I can only select one point and then AutoCAD exits the command without any Esc or Enter key pressed by me
In contrast when I select the Multiple Points in the expanded Draw panel, I can select as many points I want and then I can exit the command by pressing Esc key
Is there a system variable that causes this difference between PO and Multiple Points? How can I make PO command work like the Multiple Points?
0 Me gusta
Responder
Soluciones aceptadas (1)
766 Vistas
2 Respuestas
Respuestas (2)
Kent1Cooper
Solución aceptada
You can do what that menu item probably does behind the scenes:  Use the MULTIPLE "prefix" command:
Command: MULTIPLE
Enter command name to repeat: POINT
Current point modes: PDMODE=0 PDSIZE=0'-0"
Specify a point: .... {as many as you want} ....
You could simplify that by adding MU as an alias for MULTIPLE with ALIASEDIT.
You can put that into a macro command in a Tool Palette button:
^C^C_.multiple _.point
or, alternatively, with the *^C^C prefix that makes what follows repeat automatically:
*^C^C_.point
Or, you could even UNDEFINE the native POINT command, and make your own new definition of the command, incorporating the MULTIPLE command before calling up POINT.  That could have one advantage over all the above approaches: it could be built to allow Enter or the space bar to end it, in addition to ESCape [all the above approaches require ESCape to end them].  It would also have the advantage that you could just type in POINT or even just the alias PO at the command line [not limited to picking on a menu item or typing in two command names], and it would use your definition of the command.  If that is of interest, write back.
Kent Cooper, AIA
imadHabash
This is because it's designed to act like that .
This is also because it's designed to act like that . Here you select a different command than the first one .
No .
Imad Habash
0 Me gusta
